Potterton plume displacemt kit
3 Aug 2009
Somerset
Hello
I’ve installed a cctv camera too close to the external clue of my potterton boiler. The camera is recording the steam/gas too frequently.
I can move the camera a little higher I guess but think It will continue to record.
Thoughts on flue deflectors? I’ve looked online and found a couple but there aren’t any instructions.
any suggestions on fitment and even if it will help?
https://www.directheatingsupplies.co.uk/baxi-flue-deflector-kit-248167
https://www.screwfix.com/p/baxi-plu...Ln4tjKKSxwEzeBZhtWRoCS58QAvD_BwE&gclsrc=aw.ds
thanks
They aren't for DIY installation. Consult your local Gas Safe Registered installer about what's possible for your boiler
Great thanks. I can do that, but I’ve managed to fix the boiler itself previously by changing the gas valve.
I think this should be easy to fit, just need guide
I've given the guidance you need - call a professional. It's not just a case of lobbing some flue on there and hoping for the best - it needs an electronic combustion analyser to check that the conurbations is still correct. We're not allowed to give DIY gas advice on this forum
