I was cleaning the bath tub and I had unscrew a cap from the side of bath tub (where the hole is located) below:
[![Whole bath tub][1]][1]
The cap consists of 2 parts
art A & B as below
[![part A & B for cap][2]][2]
When I removed part B, the part A is connected by a screw, which comes from the drain overflow system behind the bath tub wall.
Here are the layout diagrams (assuming the screw coming from behind of the bath tub wall):
[![top view of part a with screw and part b][3]][3]
Here is the top view of part A with screw (which comes from the overflow drain system behind the bath tub wall)
[![top view of part A with screw][4]][4]
Lastly, take note that the white part of the part A would be glued to the bath tub wall. Again the screw comes from the overflow drain system behind the bath tub wall.
[![back of the part A with screw][5]][5]
However, by accident, I had pushed the screw into the inner part of bath tub.
1) Would there be any problem if I left the screw inside the bath tub?
2) The part A is held on the bath tub wall by a glue. What glue should I use to stick the part A on the hole? This is how I stick part A on the bath tub:
https://i.stack.imgur.com/dYzvr.jpg
[![how to place part A to bath tub][6]][6]
3) What screw, nut, bolt or other tool to hold part B to part A?
[![how to put part B to A][7]][7]
Any suggestion is welcomed! Let me know if you need more photos! Thank you.
**EDITED**
Further investigation reveals that there is a bath tub drain system installed in this bath tub, as seen in the image below:
[![Bath tub drain installed][8]][8]
This is the best I could do to get bath tub drain system out to the wall of bath tub, while waiting for a solution from you all on which glue to buy.
[![enter image description here][9]][9]
So only question remains now:
How to join part A, part B to the bath tub drain system behind of the bath tub?
What glue should I use to hold the bath tub drain system to the bath tub wall?
Thank you.
[1]: https://i.stack.imgur.com/74Uwf.jpg
[2]: https://i.stack.imgur.com/Bxn2Q.jpg
[3]: https://i.stack.imgur.com/VLx6F.jpg
[4]: https://i.stack.imgur.com/QB7c9.jpg
[5]: https://i.stack.imgur.com/sKLO7.jpg
[6]: https://i.stack.imgur.com/dYzvr.jpg
[7]: https://i.stack.imgur.com/VvDUa.jpg
[8]: https://i.stack.imgur.com/mSqxB.jpg
[9]: https://i.stack.imgur.com/BFhFo.jpg
**EDITED**
Thank you.
