Seems to be just like RF predicted.Hi
I have attached a photo and there are no other wires located around them in the loft.
I don't see earth wires on the blacks.
Terrible picture Ged. Does the earth conductor originate from the same sheath as the red ,or are they totally seperate.
Trim the two black conductors and fit both together in a terminal block
( Hopefully you have some). Put the red in a seperate terminal block. And the earth conductor in a third terminal block.
Power back on ,and see if the lights in rooms that didn't work ,now work.
Either those two black conductors were not making good contact with each other ,or one has the copper snapped inside the insulation ,or there is a problem elsewhere not connected to you fitting your new light fitting.
I'd have hoped the blacks have an earthwire too.In the same sheath as the red. No David Bailey me.
One black wire has exposed copper where it shouldn't.
Is the wire broken here?
Sometimes the copper can break inside, and it's not obvious at first.
Other things:
Anything else been disturbed?
Any light switches been loosened off for decorating?
Any holes recently drilled in walls?
Can you remember how the old light was wired?
Any switches not turned on at mains? (RCDs can trip while electrical work is being done and go unnoticed).
Got to be a broken wire somewhere, at a guess.
