I've had a structural engineer in to look at a couple of walls, and he's made some recommendations:
I also want to create 2 new doorways in load bearing walls on the first floor, so I'll need to install some lintels (I asked the structural engineer about this, but he said he didn't have to spec those as they would be "standard" (which means very little to me at this point, will need to research more).
I hope to do all of this work myself, and to keep costs down even more I was hoping to keep the costs related to building control down too. So can I put in a single application specifying all the above to the best of my ability and then just ticking them off as I go along (which might take a year)?
Or are their rules, and will I have to file multiple applications?
- Move purlin support in loft from Wall A to Wall B (they are approx. 1m apart)
- After which I can remove Wall A, as it would no longer bear the load of the roof
- Bolt 2 new roof joists of identical dimensions to the one in situ to the one in situ
- After which I can remove Wall C (which sits under Wall A, so I'll do it in this order)
- Wall D isn't load bearing, so I can remove it
