From 2-gang to 1-gang light switch
29 Nov 2020
Hello
I thought I had an easy task but the solution escapes me!
So, I’ve got this 1-way 2-gang dimmer switch controlling my kitchen spotlights (half by one dimmer, half by the other), and I want to replace it with a 1-gang so I can control them all at once. I don’t have access to the ceiling rose or box but I attach a drawing and two photos of the current set up (2-gang), which works fine.
Both red cables measure 240V, the black 2.7V, the blue 2.1V and the yellow 0V.
Could you please advise which configuration I should use to turn it into 1-gang?
(I also attach the new switch diagrammatic instructions)
Many thanks
Stavros
View media item 105621View media item 105622View media item 105623View media item 105624
You should check that your new dimmer is suitable to dim 15 lights, total wattage should be considered and with Led there is often also a limit to the number of lamps, regardless of the wattage being in range
Are there more wires attached to that switch?
The diagram suggests that the switch needs a neutral connection. If this is the case, that only leaves 1 feed conductor and 1 switched conductor. In other words only enough for one switch.
Thanks - I’m ok I’m terms of total Watts (but not sure how I’d find out about total number - they are LED indeed)
No, there are no more wires attached; there’s no neutral (or ground) on the existing switch.
But the new switch requires a neutral (which makes me scratch my head) and a ground (so I’ve added a short cable from the G of new switch to the back box ground point).
Sorry, it sounds like I was mixing up the old switch and the new wiring diagram.
Apparently this is a quite common problem as most smart switches require a neutral but most UK wiring configurations don't bring the neutral wire to the switch. I'm wondering... if I pull down one of the spots and connect the neutral to the line (e.g. black) and then at the switch connect the line (black) to N - would that work?
What's that yellow wire on the left doing, is it connected to anything ? If not you could attach it to a neutral and tape bothe ends with blue pvc tape.
I tried that but no luck. I think it's another ground (no idea why there would be two in the same cable).
Are you sure?
Yellow is a live conductor, not an earth.
It may be connected to earth at one end if it's a spare.
If this is the case, disconnect it from the earth terminal and it can be repurposed as a neutral.
Of course I’m not sure - I hardly know what I’m doing!
However, I tried this configuration (green/orange line is that yellow) and both circuits were permanently off
