Kinked braided hose on bath tap - should I be worried
23 Mar 2020
Hi.
Just had some repair a small leak I had on a bathroom tap - it's an awkward spot so got someone out to do it. Apparently, the washer was gone.
They have fixed the leak but I have just managed to have a proper look, and it seems like they have kinked the braided hose.
Should I be worried about this - is this a problem waiting to happen? I can tell from the sound that the water is restricted a little. I understand that it's an awkward spot, but it doesn't seem right to me and don't want to take the risk.
Edit: The photos taken from outside the bath - the one that was fixed is the far (cold) tap - not the closest one you can see.
IMG_2257.jpg IMG_2258.jpg IMG_2261.jpg IMG_2262.jpg IMG_2263.jpg IMG_2264.jpg IMG_2268.jpg IMG_2270.jpg IMG_2271.jpg IMG_2273.jpg
The flexi on the other bath tap doen't look very clever either. Hard to tell from the pics.
Hi.
View attachment 214037 View attachment 214038 View attachment 214039 View attachment 214040 View attachment 214041 View attachment 214042 View attachment 214043 View attachment 214044 View attachment 214045 View attachment 214046
Where was the leak from? Why was it necessary to disturb the pipe to the tap?
Did you pay for that repair? Just being inquisitive
Overlooked mate? :D
That's the point, "apparently". If water was dripping from the tap outlet, why disconnect the pipe, let alone make such a pig's ear of replacing it? But assuming it's the original flexi and it wasn't kinked before, it shouldn't be difficult to refit it without a serious kink. Just make sure the flexi doesn't turn as the nut is tightened.
I would class this thread as a wind up, water would not flow through to the taps.
Andy
It's not a wind up - flow was restricted but was running. Anyway, it's been sorted now with a new flexi pipe.
