Halogen light lead behind skirting?
19 Dec 2009
Hampshire
Quick question lads i have a fire mantal with 2 halogen lights is it legal to run the plug lead behind the skirting? Thanks
Electrical installation instructions are not law, but can be used in a court of law, and odd as it seems just under the ceiling around the room is considered as a safe zone, but at floor level it is not, unless some thing shows there are wires there, so using skirting trunking is OK, but home made skirting trunking is not, which I know seems daft.
Using cable buckles and having the cable visible on the top of skirting is OK, but hide behind skirting is not, which I know seems daft, if there is some electrical item then vertical and horizontal from the item is a safe zone, so skirting with lights set in to it and cable behind would be OK as lights show there will be a feed cable. But it stops at any corner.
It is all down to safe zones and where one would expect to find cables.
Thanks eric I know about safe zones for electrical installations but i ask this question because this is not an installation as such and just a wire from 2 external halogen lights as you can buy skirting with halogen lights in them which made me wonder
Edited
Edited
The basic idea is that there needs to be some indication, by looking at the skirting, that there could be a cable running behind it.
Hi dave i was planning on drilling a hole in the skirting by the plug socket for the lead and plug to exit from so the plug and lead would be an indicator ?
It should be an permanently installed electrical accessory which is connected to the circuit in question. The accessory creates a Safe Zone.
