I’m trying to fit this rather heavy light to a plasterboard ceiling with a plastic decorative ceiling rose.
I had it up temporarily with a screw in hook and (don’t judge me) cable ties but now that we’ve decorated, I need a permanent solution.
directly above the centre is a 100mm joist.
For other ceiling lights I’ve fitted a piece of wood between two joists but with this being directly above, I can’t do that.
my only thoughts are a longer screw in hook that will come down far enough to hook the bracket over - or a bolt all the way through the joist - not sure if that would work though the hole would need to be near the edge of the joist.
