Hanging a chandelier - between joists
6 Jul 2004
Sussex
My wife wants a simple (for candles only) bent steel chandelier, weighing under a kilo. to be hung on its one hook from the ceiling before Christmas. Simple - I would normally position it beneath a joist for a firm fixing. But... the middle of the dining table is between two joists, which is exactly where it has to go, so it has to be a cavity fitting.
I can't even access the floor above to add a noggin. And she would prefer me not to fit a wooden pattress to the ceiling and hang the hook from that.
The most reliable, spring-toggle fixings only work with the screw supplied and not with a hook, and I am dubious of using anything more flimsy - imagine the result if it let go and descended directly onto the Christmas cake. Also, many cavity fittings need to fix a firm surface like wood to plasterboard in order to hold them in place while being screwed up, although I supposed I could use a flanged hook.
Any suggestions or recommendations, please, to save our Christmas meal from disaster? Many thanks,
Alec.
You can fix a hook to a spring toggle, but you'll need one with the same thread, obviously......you could probably fabricate something from a long 5mm screw - plus some imagination!
Having a flange (nut and washer) will allow the toggle to pull tight.
John :)
I assume the light fitting has cover plate that fits tight to the ceiling. If so, then you could make a hole large enough that would let you slip in a strip of steel, say 20mm x 3mm of 300mm long. In the middle of this you have a tapped hole to hang the fittings from.
This strip will then spread the light weight over a much larger area of the ceiling boarding.
Or a strip of slightly thicker wood. ;)
Thanks for those ideas. Actually there's no cover at the top, just a plain chain all the way up; however, I could simply poke a strong steel rod through the top link and ease that up into the ceiling. I would still need to cover the larger hole, but I could probably rob a conical cover off another light fitting. Thanks, guys!
Alec
Hook into both joists then a (matching the chandelier) rod between them.
Hang the thing from that.
It can move anywhere between them then and will be a talking point :
