Nothing wrong per se with 3/0.029, the major part of my lighting is still wired with it. It could certainly do with a decent inspection but has not turned sticky green.View media item 26849View media item 26849That wiring is really old and should have been replaced decades ago. The neither of two switches of the two gang in your first photo are NOT wired as a two way light switch. Two gang = two separate switches toggles, in one faceplate. Two way means there are two switches able to switch one light on and off, usually found top and bottom of a stair.
and when do you think those cable were installed?Oooh! Red white & blue lovely!
BTW. Cables that old don’t produce the green goo. It’s some of the PVC cables, produced 1965-1970ish.
Good spot and totally correct.The existing switch plate looks like it is metal and needs an earth connection , is there an earth terminal on the switchplate ,behind the connector block ? If so ,you need to replace it with a plastic switchplate.
1950s.and when do you think those cable were installed?
1950s.
Not necessarily - the wooden boxes were still used even after the launch of the standard knockout box in the 50s.
The house was built in 1968.1950s.
