- Joined
- 8 May 2017
- Messages
- 10,676
- Reaction score
- 2,877
- Country
How long have you lived in the property ?
Did living room rads work this time last year ?
I assume your system is pressurised ,does boiler have a pressure gauge ?
If turning off EVERY rad including towel rads ,and just living room rads ON doesn't result in the living room rads heating ( with programmer not calling for domestic hot water ,only central heating ) Then the living room rads valves are suspect.
Are you certain the living room rads lockshields were not / are not closed ?
As the living room rads worked last year, and you obviously have not closed their lockshields ,they can be ruled out ,unless there is a blockage,which is unlikely on both living room rads.
The two towel rads need one of their valves closing. A pic would be good ,but your description sounds like a wheel head. They close by turning fully clockwise.
one question though...TRV is likely to be the "In" water flow to the radiator, right? If that's the case, when I bleed the radiator, should i see water coming out? I bled radiators last evening and both radiators had plenty of water coming out of them. water wasnt warm though.
