Hi all,
Hope someone can advise as I think I have started to overthink this!
I originally had a trailing extension lead plugged into the double socket which ran up a wall and into a cavity behind a wall mounted TV.
Doing a small redecorating job I want to neaten this up but also hard wire in a new 1.35kW heater.
Pictures:
First double socket - ring main, looks like this is the entry point from the fuse box
Second socket - fused switch for old heater (now removed)
Third (empty) socket - heater single control switch connected to fused switch (was here but I have removed it)
- I would like a dedicated double socket mounted behind the TV (in the rear cavity), to power the TV and maybe a soundbar
- I would like to hard wire the heater directly into the fused switch
With not being able to add an additional spur, I can't think how this can be best achieved without having to insert another socket in the ring (which I would rather not do as cables are quite tight), or have another trailing extension lead.
Any advise appreciated!
Pictures:
