Either/Or
Do you not regard the light switch as "an accessory or a point in wiring"?In this application, there is no earth wire to the switch, hence the use of 2 core cable for that.
No
No
No
No
No.
Most switches have an earth connection, and T&E or 3 core cable would be used, either connected to the switch itself or the box it's fixed to.
Door switches only have 2 terminals, there is nowhere to connect any earth, and it would be entirely pointless using 3 core cable for them, assuming you could actually get the larger 3 core cable to fit into them.
I do like to complicate things.
I'm confused surely the lights come with covers on.Also, might have to look for a shade as I wouldn't want somebody putting something too close and causing a fire. Should I be looking at a bulkhead light. Bloody hell, I do like to complicate things.
And why you fitting switches if the lights have built in motion sensors
Suely just a permanent supply to each, turn down the sensitivity and job done
No, it won't contain the required number of terminals, so additional terminals will be needed.I'm assuming the wring will be the same.
If they did, whoever opened the cupboard would notice immediately.slightly concerned that someone might rest something against the bulb
2 core flat 0.75mm²So is it flexible twin core cable
With the door closed the light is off, so nothing happens.
The lamps suggested earlier are 4W LEDs, barely even warm.
2 core flat 0.75mm²
That is true provided the switch does operate to be electrically OPEN when the door is CLOSED. As I mentioned a failed switch left a light ON in the closed clothes cupboard and a fire was started.
