Fitting Worktop into awkward shape
28 Jan 2011
Manchester
Hi
I need to fit a kitchen worktop into an awkward shaped 2 sided alcove with a boxed in waste stack in the back left corner.
I am familiar with scribing, but I cant quite workout how to scribe a worktop into an alcove. I have attached a plan pic of what im trying to do. Can anyone offer any tips on how to scribe it to the two walls and also around the boxing in - assume none of the walls are that straight and not at 90 degrees......
I'd just use a bit of cardboard and cut to the shape, then use a template.
Assuming you will have tiles, upstand or similar it doesn't have to be mm perfect. Even a bead of silicone will cover any small imperfections.
In any case, use a long square on right edge against the wall (yellow line).
Measure how much out the edge of the worktop is from right wall (yellow arrow) and mark it on your worktop.
Measure twice, then cut.
Now, with the left side.
Measure yellow lines 1 and 2, subtract 5mm from these measurements and mark it on your worktop.
Measure again and then cut.
Now the pipe box.
Measure yellow lines 1,2,3 and 4 one at the time, subtract 5mm and mark your worktop, one measurements at the time so not to get confused.
Measure all again and then cut.
If you've measured correctly your worktop will fit perfectly, leaving a 2.5mm gap right and left.
If the long wall is bowed, you can chisel the plaster to get the worktop flush.
@johnny2007 obviously you go into a bit more detail than my explanation in respect of measurements, but personally I would do the cut you've suggested first as the very last one.
My focus would be on getting a good fit into the corner with the waste pipe first to get that right. If the person buggers it up, then there the potential to start over on cut in a bit further on that edge... depending on how much worktop you've got spare on the right.
If you cut the right hand side first, then you've only really got one shot at getting the left corner correct... and any major fluff-ups and your back needing to buy another worktop.
Sorry, thinking with joiner's mind.
You're right, cutting the left side first might be easier.
However if one measures correctly, it shouldn't make any difference.
Now the pipe box.
Thanks pal. That's a really good explanation.
