Electric element radiator wiring
29 Mar 2016
I am swapping out 2 vertical radiators on my central heating system and would like to convert one that is removed into an electric one for a new extension.
What I would like to know is does this converted radiator have to be hardwired through a fused spur or can it simply be plugged in to a ring main socket. The element will be 600w and the extension is neither a wet room or bathroom so no risk of water ingress.
I have in the past used a 3kw oil filled radiator in the room on the same socket that this radiator would be plugged into when needed. Basically winter months.
Thanks in advance
Great if can be plugged in. None of the elements I have seen come with a plug though. So no clues there really
So you used a 3kW heater before and will now use 600W. 20% of the heating effect... Are you expecting it to work as well?
No not at all but the 3kw oil heater is mobile and used elsewhere.
All I need to know is does running the electrical element run radiator from a plug not against any regs.
I'm not an electrician, obviously but all the elements I have seen say need to be wired to a fused spur. But is this because they are generally used in bathrooms.
No. Assuming they are less than the 13A of a plug and fuse.
600W is a quarter of an Amp 2.5Amps.
Saying the element needs connecting to a fused spur is misleading as neither a fuse nor a spur might be needed.
The cable is actually the spur - but many call a Fused Connection Unit a spur so who knows what they mean.
Not really, it is just something they have written.
Thanks to you all for your help and advice, really appreciated.
So many suppliers saying having to be wired to a fused spur. Example attached
That is because the product is described as for a towel radiator. These are used in bathrooms. Sockets not permitted in bathrooms, but fused spurs can be ( depending on location).
But it is just an electric element not a radiator. So surely can be fitted to any radiator and doesn't have to be a towel radiator or placed in a bathroom?
Yes. But the makers envisage they will be mostly used in radiators in a bathroom. That’s why they are described
Towel Radiator Element!
I missed a word out of my post. Edited now for clarity.
Most people wanting an electric radiator for other rooms would, I guess, install a panel rad or a ready to go radiator (like an oil filled rad.)
Thanks all, answers my concerns and I've since found companies online that put these elements into many types of standard or vintage radiators not just towel rails for bathrooms.
Thanks again
