Height of chimney pot
14 Aug 2020
Hi
Just measured up to get a matching pot for my chimney, what height is normally covered by the haunching around the pot? The pot is showing 450mm above this
On mine I did 2 courses of brick plus the flaunching height
This is the current set up at the moment...IMG_5420.JPG Just want to have the new pot matching roughly with the one bottom left of this photo
Looks like the pots are held in by just the flaunching on that stack, which is quite common. You need to cut off some of the flaunching and probably use some slate to hold the new pot in place. Ideally a pot should be built into the brickwork as shown above, but in many cases tall pots are only held on by the flaunching.
So the height from the top of the chimney to the flaunching is 450mm, would the chimney pot need to be say 600 mm in total to allow for the new flaunching around it, and to match the height of the other pot?
You would have to measure the thickness of the flaunching and add that to the height that you want. Ideally a pot should be built into the brickwork at least 25%. This is easy when the stack is being built, but not so even in a case like yours. If the chimney has a clay liner it's easy as it goes on top of the liner.
Before liners were used, the pots would often splay out to a square base so that would just sit on the edge of the brickwork. Then 2 over sailing courses were laid and then the top one brought back in.
The house was built in 1910 not sure if it has a clay liner. This is the view looking into chimney
There is no liner in that flue. You need to cut back more of the flaunching. Then measure up from the top of the brickwork for the new pot. Probably need a few bits of slate bedded on top of the brickwork to catch the edge of the pot. When it's all filled back it will hold the pot in place.
