Hello,
I've had my entireroof replaced last summer (only felt, batten and tiles)
I didn't know at the time but I now know I should have had building regulation approval which should have cost me £200
Regularisation will now cost me £300 (which I'm ok with); I also know they'll only be looking at loft insulation.
I currently have different thickness of insulation:
- some places with 270mm (or maybe slightly less) of insulation which had been boarded over
- some places with 270mm but not boarded over
- some places with less than 100mm and boarded over
- I cannot really see what there is at the eaves as the roof pitch is quite low and it would be difficult for someone to add something there
Are building control likely to ask me to top up insulation to 270mm?
I also got this online quote from a company that can access the Green Home Scheme:
£345 payable after the grant voucher is applied
The quote mentions topping up to 270mm, but I'm unsure what that means and what materials they'll use; are they just unrolling fiberglass into the loft? Are there other materials available that don't release fibers into the air?
Is there any special tecnique that could be used to access the lowest points?
I know I can just ask them, but I would like to get some more info before...
Is it worth considering doing the work myself?
