Flexible shaft-extension for drill.
20 QUID!!! You know it's just cheap tat from China?
https://www.ebay.co.uk/itm/184671413645
I've got one in a drawer somewhere, never use it. It can't transfer any kind of meaningful torque it just wants to twist up on itself.
Use one of these, much better. surprisingly good bit of kit.
NOTE - just a DIYer NOT Trade
i have a flexible attachment , doesn't bend that much - works OK for slight angles, mine only works on a normal drill chuck - NOT Impact , i purchased from toolstation or screwfix for a £5
BUT i have also used this a few times, given as an xmas present from FFX
https://www.ffx.co.uk/product/Get/D...ct-Rated-Right-Angle-Drill-Bit-Holder--8-Bits
Long story, but i now use this almost all the time for difficult right angle jobs
https://www.screwfix.com/p/dewalt-d...kkD41n70j7OTRGABNhgaAl8YEALw_wcB&gclsrc=aw.ds
had this on my list for a while now
https://www.amazon.co.uk/dp/B01KZ0W...olid=1UQXK3AIKKSCS&psc=1&ref_=lv_ov_lig_dp_it
I have something similar to the one the OP is talking about, it rarely gets used because it is a PIA to use. Mine is a Trend Snappy one and cost less than the OP's one (about £15). I doubt it was worth it
So how do you get screws in/out of awkward places?
A variety of ways. First thing is long bit holders (150 and 300mm) which often allow me to use the cam out feature of Pozi head screws - and they are cheap (look for Mileaukee or Saxton brands).
I also have a couple of extra long screwdrivers (CK brand, PZD#1 and PZD#2). Next, I have a Trend Snappy offser driver - a sort of bit holder with a universal joint in it.
Then, if that doesn't work, I have a Makita angle impact driver, generally used with 50mm long bits.
Whilst mine (above) is hardly pristine, the fact that with a 50mm bit in it I can get it into an 85 to 90mm deep space (below) is very handy at times. With a 32mm bit you'd get another 18mm to play with (72 to 80mm gap)
And finally (normally only in kitchens) I have a little 12 volt Milwaukee drill with exchangeable chucks, including a right angle head and an offset head.
TBH I rarely need the Milwaukee drill because the other three techniques generally do the trick, either singly or in combination. In fact the first two generally save the day. I've tried low cost angle drive heads, but find that they aren't particularly robust,whilst the flexible shaft type extensions are difficult to use for screwing, won't allow much torque (so you are limited to shorter, thinner screws - no good for 5.0 x 100s!) and are almost impossible to control safely when drilling
£3.75 on Amazon
I've had a similar one from a pound store for over 20 years
This looks amazing, it apparently enables you to put screws in around corners etc. Is this too good to be true? Anyone use one?
Jeff, you have trouble putting a nut on a bolt, how on earth will you be able to screw around a corner.
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Andy
