Saw for cutting 1/2" ply
4 Aug 2019
Ireland
Hi, I was thinking of getting something like this for cutting out a few awkward bits of 1/2" ply in my bathroom. I'm getting it ready to re-tile.
https://www.amazon.co.uk/gp/product/B07J2DP8WN/ref=ox_sc_act_title_2?smid=A2RHMXDA8EAZMB&psc=1
It's not going to be use for heavy work.
Unless you guys can recommend something better, for in around the same money :)
Can you recommend a compatable wood cutting blade for the Bosch Multi-Tool.
I've one like this, only its an older model.
https://www.amazon.co.uk/dp/B01L70M...ef_=pd_luc_rh_ci_mcx_mr_huc_d_01_03_t_img_lh#
Thank you.
I can't see any advantage in that saw over a small conventional one, TBH
This
But from your description a Jigsaw may be better.
Sorry, should have said, I might have to remove 1/2" ply from a stud wall and I would have to cut all the way across the top of the ply about 5 or 6" down from the ceiling. About 7 or 8ft in length and was thinking of one of these.
https://www.amazon.co.uk/gp/product/B00MYZF2KW/ref=ox_sc_act_title_1?smid=A3P5ROKL5A1OLE&psc=1
If I were to do that job I would use my 10.8 mini bosch circular saw, so I guess the works saw is basically the same thing.
OK Thanks so would you think the WORX WX426 should be a good enough wee saw, esp for a bit of light work :) ?
Thanks.
will only cut in strait lines
if you need any curved cuts you need a jigsaw
I've got the dewalt version of this worx saw, and it's amazing for sheet cutting. Much easier than jigsaw or full size circular saw.
I'd highly recommend getting one.
Thanks what model? is it electric?
