Seen nothing saying not allowed, the main thing about under floor heating is ensuring it does not over heat, 27°C is normally the limit for floor temperature, with wet the water temperature is controlled, with electric there are two common methods, one is a sensor in the floor, the other is special chemical heating tape (RayChem) which changes resistance as it heats up, the former can have hot spot issues where some thing is placed on the floor, the RayChem is claimed not to have that problem.
Clearly using two one must ensure if both are used this can't cause over heating, I know with the one I laid there was too tight of a bend in the pocket and when the sensor failed it could not be replaced, and the sensor wires can't easy be extended so there are some logistic problems to ensure it can be maintained, I would have thought it would be too much of a problem ensuring correct control, and having electric and water seems pointless.
