    Dismiss Notice
Electric underfloor heating advice needed please.
Discussion in 'Electrics UK' started by Teachmesomethingnew, 28 Sep 2011.
  1. Teachmesomethingnew
    Teachmesomethingnew
    24 Jan 2005
    49
    Thanks Received:
    2
    Country:
    I have a small conservatory that is about 2.5m square. It us cold in the winter and roasting hot in summer. I want to get more use from it in the winter so I fancy electric underfloor heating. The floor is currently ceramic tiles on concrete slab with no insulation as far as I know.
    I intend to use a kit underfloor heating kit and get a tame sparky to hook it up. I ideal want Lino or similar softish floor as it's going to be a child's play room.
    What can I do to get the best from underfloor electric heating in this situation? What should I be looking at doing about insulation, floating flooring? Etc.
    I've done lots of household refitting before but never used underfloor electric before so any advice warmly welcomed.
    Cheers
    Andy
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Do you intend to rip the tiles up or lay on top?
    It would be a good idea top have a level surface to lay on top.
    So regardless of what your subsurface is it wants to be level.
    Then depending of the kit you buy, which should offer instructions.
    You should be looking at getting something like 6mm insulation boards, then your heating mats, a vapour barrier and then base board, top board prior to lino.
    The system you purchase my differ a little.
    The floor level will raise by about 15mm.
    Do you have an idea of the kit you are buying?
  4. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    double post? :confused:
  5. securespark
    securespark
    11 Jan 2004
    36,898
    Thanks Received:
    1,269
    Country:
    It takes 13 hours to build a Toyota, and 6 months to build a Rolls Royce.
  6. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,444
    Thanks Received:
    2,116
    Oxfordshire
    Country:
  7. flameport
    flameport
    10 Mar 2007
    9,813
    Thanks Received:
    1,958
    Poole, Dorset
    Country:
    Underfloor heating won't solve either of those problems.
    Underfloor heating is typically 200w per m2 or less, which is far too little to heat an uninsulated space such as a conservatory.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
