- Joined
- 27 Jan 2008
- Messages
- 23,753
- Reaction score
- 2,679
- Location
- Country
From reasonable early days I knew there were different types of RCD, however I thought the type A was designed to work with
a simulated sign wave, and was under the impression used in narrow boats and the like, and also the whole idea of the active RCD was so if there was a volt drop it would fail safe, a RCD used with a 55-0-55 volt supply may fail to work as the voltage is too low, and finding a RCD rated at 55 volt to earth was not easy.
However it seems I was wrong, and with solar panels and electric cars we have a large DC device which under fault conditions could impose DC onto the mains supply, pulsed DC has been with us for years, there are many devices that used half wave rectifiers, what is new is some thing which under fault conditions can put a large smooth DC current onto the mains, I have seen this once, with a ward leonard control on a crane, here the regenerative braking when dropping the load caused a problem with the cycles shown on the frequency meter hitting over a 100 Hz, but from the sound of the engine the Cat diesel was clearly not doing over 6000 RPM it was more like 3000 RPM so clearly not really 100 Hz, however the fault caused the brake not to engage and the crane dropped its load, which resulted in all the tower cranes on building of T5 being stood down until the fault was found.
This was at the same time as my accident so I did not find the outcome.
However it is clear like electric cars and solar panels motors can also generate DC which can end up on the supply, however ward leonard is not used that much and not in domestic, it may be the odd lift could cause problems, but in the main looking at solar panels and car batteries. I can't thing of anything else with stored energy, but as said the John Ward demo raises more questions than it answers, I had thought type B worked with DC but he put a 50 mA and 250 mA current through the RCD without it tripping, I suspect maybe due to no voltage to work electronics, but clearly from the demo they both failed to work at 30 mA. Yes one worked with 30 mA AC, but not with 250 mA DC.
But it seems likely unless there is some stored energy, be it a crane with a suspended load, car battery, or solar panel, the chance of have smooth DC in a domestic installation is very low. But in an industrial environment with motor drives then it is very different. OK we do have some in domestic, washing machine and refrigeration both use inverter drives, don't think too much of a problem with refrigeration but a washing machine can take some time to stop, so it could delay a RCD tripping by 3 minutes or so.
So if we have a earth leakage at the same time as doing the washing then it could cause the RCD not to trip. But with anything with regenerative braking one has to ask what happens if a RCD trips? Would fitting a RCD be dangerous?
