Self levelling screed around waste pipe
14 Feb 2021
I'm just prepping the floor ready for SBR primer and then self levelling mix.
What's the best way of protecting the waste pipe area in the ground so the self levelling goes around it nicely making sure none goes inside? Ive seen someone create a 'dam' using foam and then cut it away and make good the area afterwards. Is there a simpler/better way?
Thanks, would I self level up to the inner line or outer? The outer being the edge of the clay pipe in the ground
