Can I use 1.5mm cable to supply a single socket. Cable will run behind a plasterboard wall. Cable run will be about fifteen centimetres. Breaker is 20amp for the circuit. The intention is only to use to supply a low current device (home automation microprocessors).
Using 2x 1.5mm2 in parallel is discouraged I think. Due to the location in a boiler cupboard is unlikely that someone will try to run a heater. They'd have to walk past several more convenient sockets to access it.
That, in itself, is irrelevant - (the common situation of) half a dozen (or more) double sockets on a circuit wired with 2.5mm² cable would dramatically 'exceed the current rating of the cable' if all the sockets were fully loaded.
