D
Deleted member 267285
Removed at poster request
I don’t think they should be. The copper pipe is the Pressure discharge pipe which can just be vented to outside and any discharge needs to be seen whereas the condensate pipe can’t be left to just drip, it must be routed into a drain or soakaway as the condensate is slightly acidic.Sorry, not what I meant. I meant, is the condensate pipe and copper pipe joined inside before going outside?
Get a small child to do it if it is indeed beyond your capabilities , it involves pulling a solid plastic pipe out of a flexible connector , if you are not strong enough call on @gasbusters he will dust and polish the boiler at the same timeSo, without disconnecting anything ( this would be beyond my capabilities! sorry ) , I see no dips on the plastic pipe under the boiler.
Or try weetabixI do not have access to a small child. I guess I will now need to arrange the kidnapping of one![]()
really ?????They did not fit the flue correctly. It was not at an angle and it was also less than 1200mm from the nearest bedroom window.
So you have a leak in your pipes
