Best Wet Underfloor Heating?
27 Sep 2010
I'm building an extension that will be used as a dining room. I would like underfloor heating! The floor will have 100mm PIR, screed then LVT.
Is it best to get the underfloor heating layout designed? The room is 9m x 3m. Any suggestions on who can design it?
Who is the best manufacturer? Would JG Speedfit be OK? Should I run 2 loops as the floor is large?
Any other tips appreciated!
NuHeat will do it for you - full design, specification, and guarantees that it will heat your room as expected assuming it is installed correctly
Thank you - I will give them a ring Monday
