The plug provides pull out resistance and allows you to hard fix an item by pulling it furmly onto the surface of the wall.
I know.
You aim for a snug fitting plug at about 1/4 to 3/4 of the depth of the hole.
Well, all I can say is that I have never, ever, seen this recommended:
Nor ever encountered wall plugs without a lip designed to stop you driving them in deeper than flush. Obviously with a drift you
can drive them in, but they are designed to not have that done to them.
The length of the screw ensures that if the screw drops it will, by default, wedge itself in the hole, this resisting further pull-out. In a situation like this you need to aim to over engineer the screw rather than make it just big enough simply because it as the ladder is loaded and unloaded there will be a tendency to pull it outwards.
Some of the loading will be shear, and lets not forget that the brackets will have at least two mounting points.
And if you dont have half of the screw with nothing but air around it its a lot less likely to drop.
You don't normally use more than a single plug per screw because it simply isn't necessary,
I didnt suggest using more than one plug per screw. I said that brown wall plugs are not long enough to take 80/100mm screws.
This will be fine, subject to confirmation that the wall isnt ropey
If the wall is thinner than 80mm (maybe single skin brick) then you'd still need to aim for the longest screw you could.
Fine, but I see no point in only having half, or less, of the screw in the plug, and the rest of it in thin air. Once the screw is all the way through the plug, and the plug is fully expanded, the threads in thin air are going to do zilch.
BTW 6 x 100 screws aren"t a "larger, fancier fixing" - they are commonly used in structural work, sign box installation and the like and are generally an over the counter size in an ironmonger timber merchants
I wasnt talking about the screws.
I was talking about 80/100mm long plugs.
