I really hope not. What was the main cu connected to?The tails from the old meter went into the shower box then out again to a pull switch in the bathroom, then onto the shower unit, as I remember.
Maybe i put that wrong. The meter went to the cu unit, which in turn went to a pull switch in the bathroom, then to the showerI really hope not. What was the main cu connected to?
Sorry, I'm not an electrician so bear with me, the tails originally went directly from the bottom of the meter to the correct access point as shown on the right of the photo, where the meter fitter has now inserted an earth cable for some reason, electrician who installed it came and can't understand why meter fitter has removed the tails he fitted, and put the earth where he has done. The cables to the consumer unit did the same, directly from the meter.Still not quite describing it properly..
We are only interested in how the meter tails originally made their way from the output of the meter, to connect to both the shower RCBO (the box in the photo) and the consumer unit.
Are you saying that both sets of tails, both consumer unit and the shower, went straight into the bottom of the meter? No terminal block involved (called an Henley)?
I have never seen that done, if that was the case. I suspect that whoever installed the shower, broke the seal on the meter terminals to add the tails for the shower. No wonder the Smart Meter installer left it disconnected and removed the tails.
Done properly the tails L+N) would exit the meter, go into an Henley terminal block, then from the block to both shower and consumer unit.
.... electrician who installed it came and can't understand why meter fitter has removed the tails he fitted, and put the earth where he has done. The cables to the consumer unit did the same, directly from the meter.
Except of course the seal on the cable entry, which must have been broken then replaced. Note the crimp on the (presumably Ebay) seal is smaller than the crimp on the meter proper.My old meter was quite old, no seals were broken, the 2 cables on the left went to the shower breaker box, the black box on the right is the old analogue timer clock
The large seal is from the calibration lab, very different from normal sealsExcept of course the seal on the cable entry, which must have been broken then replaced. Note the crimp on the (presumably Ebay) seal is smaller than the crimp on the meter proper.
Your shower fitter 'electrician' did a big fat bodge.
