Personalised registration plates
Status
Not open for further replies.
Safe and enough grunt to get out of trouble. I wouldn't want my family in one of your cobbled together heaps of tat thanks.(n)
doubt it is as safe as the transam
In a head on ;)
but you can drive yer cobbled together pile of tat :LOL:
As for a builder pontificating about build quality
jeez us wept :LOL::LOL::mrgreen::mrgreen:
I doubt if noseall actually knows how to lift up the bonnet
or were the engine actually is
it’s in the front noseall ;) :mrgreen::mrgreen:
not in the back ;)
that thing that is confusing you :confused:
that’s the jack noseall u use it to change a wheel :LOL:
save you calling out the AA or a tow truck
And don’t forget noseall it’s a diesel it has not got spark plugs ;)
:idea:Incidentally those things on the wheels / tyres are for pumping up the tyres with air noseall I won’t go into air pressure noseall other wise u may be further confused :idea:
best ask at the local garage they will have an explanation sheet for u may be :idea:
Mind u we have to provide basic written help sheets for some people / customers basic advice such as
it’s a gas boiler but it won’t work if there is a power cut
don’t boil a kettle under the boiler steam and electronics don’t mix
dont place a toaster under the boiler heat can damage the boiler electrics and plastic parts
error code ? Is not a boiler fault it’s no water pressure the fault would be if the boiler did not shut down
don’t leave the filling loop turned on that’s why there is water constantly running out the safety valve out let
u need to turn up the room thermostat up for heating to work
no it’s not smoke coming out the flue it’s steam no need to call the fire brigade
All the above
I am not joking either
All
The above generally causes a :confused: reaction :)
I bet yours are a real giggle:
its agas boyla but:sleep:
it wont werk if Their is a :ROFLMAO:
powa cut
dont Biol a ketta unda The :LOL:boyla Steam
And elektronicks Dont mychs:mad:
All the above
All
And as far as I know these people are not even F***** :confused::confused::confused:
A fella called Trevor Nation was at one time a works motorcycle racer for the JPS Norton rotary team
he had a merc and I recalled it spelt his surname
he had the number one digit or digits slanted to achieve the affect
NAT 10N?
It's on a Bentley.
They'd have o be goggledygookish to read your instructions. o_Oo_Oo_O
So what about this air pressure that you didn't want to go into?
Would that be because your inflated ego would burst?
Or would it blow up in your face?
Or do you need a lot of it for your dolls?
Do they go down on you?
Perhaps your uncle fritz should have used the dolls instead of the prisoners.
Status
