I have an 80A 30mA (WRS80/2) RCD protecting the supply to my open plan kitchen/living room area.
Last year it started tripping if I used my main oven in Fan cooking above 200c. Normal cooking worked fine at all temps. As did my Combi Micro/Oven which also has fan cooking mode.
I figured it was a defective element/fan so kept an eye out for a new oven and just used it in normal cooking mode in the meantime. It's getting on a bit, so figured rather then messing about trying to repair, may as well hope for a good deal on a new one. I'd always regretted going Steam Combi instead of Pyro.
Few days ago I picked up a new AEG BPK84272 on a clearance deal and wired it in. Worked fine for two days, including testing the Pyro cooking and Fan modes. But yesterday I switched it on to Fan mode and the RCD tripped. Every time I flicked the RCD on it tripped again within 10 seconds.
Kitchen appliances are all wired via fused spurs so they can be isolated. So I switched them all off and narrowed the fault down to the new Oven. With that spur switched off everything has been working fine, including the Combi oven.
As soon as I switch the Oven spur on, it starts too boot (its one of these new "smart" ovens) and the RCD trips within 10s. I've got AEG coming on Thursday, but am wondering if this is just a big coincidence or there may be an issue with the RCD. Previous oven was also AEG and had been working fine for 9 years using Fan mode.
There's a 13A fuse to the oven and short run of cable. Fuse is fine and oven does start boot process. Given the issue occurs before any cooking elements are fired up, makes me suspect it is a coincidence and there's a problem with the oven. And ofcourse other appliances all work fine on this RCD.
Any thoughts greatly appreciated.
