- Joined
- 13 Jan 2021
- Messages
- 5
- Reaction score
- 0
- Country
Apologies if this has been answered elsewhere, I had a search through but I couldn't find anything.
I am installing a 200l direct unvented cylinder in my loft. I am running all the pipework up to the cylinder, and the the G3 certified plumber will be doing final connections and commissioning.
Where I'm getting tied up in knots, is the D2 discharge pipework. The D1 discharge pipe is 15mm. The way I see it I have three options:
1) 28mm copper pipe, through the wall directly under the eaves, and straight down the wall adjacent to the PVC guttering, terminating at ground level and basketed in. Total run length around 9m, with around 5 or 6 elbows, so that permits me something like 12m of run length. Does the vertical drop count towards run length?
2) 28mm copper pipe along length of loft to opposite end, down through the wall, and couple onto a cast iron soil stack using a suitable boss. However, I can't seem to find a suitable adaptor for taking 28mm copper up to 32mm waste pipe size. If I'm going into the soil stack, I was planning on using a Hotun dry tundish, but I'm not sure it it can handle the flow rate (35l @5 bar, not sure what flow rate it would be when regulated down to 3 bar). Alternatively I'll use a 32mm HepCo waterless valve.
3) Same as runs 1 or 2, but do everything in 32mm polypropylene. However, looking at the guidance, it says polypropylene shouldn't be used outside as the UV light can weaken it. Is there a UV stabilised polypropylene?
Should I just wash my hands of it, and ask the plumber to spec and install the D2 pipe? I want it to comply with regulations, but the more I read into it the more complicated and restrictive it's getting.
Thanks,
Phil
Thanks,
Phil
