I have recently had my old oil boiler replaced with a new Worcester Bosch Greenstar Heat Slave 18/25 Oil combi boiler.
It works fine however as you will see from the attached photos the flu pipe does not appear to be fitted correctly to the top of the boiler housing.
This leaves a gap right around the flu pipe. I have googled the same picture and none I have found have the gap which I believe is called the fire stop plate.
The top of the boiler is also dented or dipped and again this shows on the photos.
As the boiler is in my kitchen I am not happy at all every time I enter the kitchen and cast my eyes on these faults.
I emailed the company and as I did not initially receive a reply decided to email Worcester Bosch.
They replied by sayng that as it was not a boiler fault and would be classed as a fitting issue then I would need to retry contacting the installers.
Eventually they contacted me and sent the original fitter around who after checking stated that it was all fitted correctly.
As I am not a heating engineer I would value any advise on this as I would like more information etc before contacting the company again.
Thanks in advance
Dave
Thanks in advance
Dave
