Sorry, this one is about climate change. All the rubbish you hear about 'climate always changes' misses the rate of change.Greenland: enough ice melted on single day to cover Florida in two inches of water
Data shows ice sheet lost 8.5bn tons of surface mass on Tuesday
All-time record temperature of 19.8C in region on Wednesday...
Greenland’s ice is melting faster than any time in the past 12,000 years, scientists have calculated, with the ice loss running at a rate of around one million tons a minute in 2019. Greenland and the earth’s other polar region of Antarctica have together lost 6.3tn tons of ice since 1994.
Actually iirc Greenland is rising s it's shedding so much weight.Nah, the ground is sinking.
How likely do you really think it is that the first and only thing those opposed to fishing vessels destroying the seabed have ever done is to start dumping boulders? How likely do you really think it is that they have tried other methods?Maybe if governments, fishermen and the ecologists had the courage to sit around a table and actually put forward their individual cases then a peaceful solution/compromise may possibly be reached.
Then they should stop bottom trawling - thats what dumping the boulders is designed to achieve.As the guy in the video says, these boulders have the capacity to upturn a boat and lives may be lost.
Do some research into that type of fishing and then say that it shouldnt be stopped.the spin doctors will turn it on it's head and say it's someone elses fault for not stopping the actions of the fishermen.
I'm not saying they haven't tried talking. Maybe they should try harder though.
Dumping boulders can also have an effect which is not a natural effect caused by nature.
I'm not saying it shouldn't be stopped. But physical conflict during a dispute is not always the best method of resolving issues.
For the SE of England this is very true, as sea levels rise London is heading the other way (see isostatic rebound) - It is an astonishing thought that sometime in the next 1000 years London will need to be moved to higher ground. Great pity the worlds politicians can only ever focus on the next 4 or 5 years.Nah, the ground is sinking.
Unless the fishermen were in diving suits underneath the dropped boulders I'm not sure physical conflict is the best way to describe it.I'm not saying it shouldn't be stopped. But physical conflict during a dispute is not always the best method of resolving issues.
Its a great pity the sea doesnt swallow up Westminster and our whole political system....For the SE of England this is very true, as sea levels rise London is heading the other way (see isostatic rebound) - It is an astonishing thought that sometime in the next 1000 years London will need to be moved to higher ground. Great pity the worlds politicians can only ever focus on the next 4 or 5 years.
