- Joined
- 10 Aug 2021
- Messages
- 8
- Reaction score
- 0
- Country
I had my rear windows and a door fitted by a local reputable firm back in March and have had ongoing issues since, enough to warrant the windows and door being replaced and I still have issues.
The reason for this post is mainly to ask another "reputable" fitter what sort of clearance do you give when measuring for a new frame taking into consideration any inner window ledge if that makes sense. I would have thought that the inner frame that is showing is near enough equal all the way round, so on the second refit before they removed the previous fitted frames, I pointed out that the bottom of the frames didnt have much clearance over the inner ledge. I was told its fine, thats allowed just as long as the beading is accessible if the units ever need replacing and then goes and silicons over the said beading, see photos.
I even had them back as I wasnt happy with the silicon finish and they redone it worse, even using silicon along the front edge of the D bead after asking them not to as I prefer it either left as is or use caulk so I can paint/wallpaper up to it. There are many other issues, mostly sorted but I dont want to get in to that just yet. Thanks in advance
