Just wondered if someone could cast an eye over this lighting circuit and make sure I'm approaching this correctly. I want to run my smoke alarms from my lighting circuit. I also want a neutral at the switch so that I can upgrade to 'smart' switch in the future.
I'm going for the "two plate" method and using all 1.5mm T+E.
I realised that if I went to the switch first then I couldn't go to the light, the next switch AND the alarm. So I thought I would run from the CU to the first smoke alarm then back to the light switch then to the lights and the next switch... as per the drawing below.
Can you see anything wrong with this?
Thanks for casting an eye over it for me (and excuse the basic drawing.... hopefully it'll make sense).
