Bosch Washer Dryer Trips electrics
24 Nov 2009
Bosch clasixx 1200 washer dryer (model WAE24162UK/01).
All the wash cycles I have tried (30, 40 easy care 30) trip the electrics about 7 or 8 minutes into the wash cycle regardless of the size of the load
The drain cycles and spin cycles work just fine.
So something is shorting out but what? And where should I start looking? And what on earth (ho ho!) would cause it to short out 7 or 8 minutes into the cycle
Thx for any suggestions
Mine is the Bosch 1400 XPress.
The arms on the support bracket/bearing shaft, known as the spider, on the rear of the drum, were corroded and cracked so the drum was spinning and wobbling which caused the drum to gouge a chunk out of the heater element thus an earth fault.
New heater element, drum and bearing set brought the washer back to good health.
