Hi all,
I selected Pod Point to do my 7kW EV charger installation. I've paid upfront, they've done all the paperwork and want to schedule the install, but they are being strangely difficult about how it's done.
They consider a 'standard install' to be when the supply runs directly from the meter box, using no more than 5m of SWA clipped to the wall, directly to the charger unit. My installation meets these requirements, except I don't want black SWA clipped my walls because I've got white rendered walls.
I've asked them to instead run the cable through white PVC conduit, and I offered to supply the conduit knowing they probably operate on very small margins (even though it's less than £5 of materials including clips and fixings).
However the person booking the installation is saying this is not possible and that:
1) They will not supply conduit.
2) The installer will not be able to run the cable through conduit, even if I supply it.
3) They will not run the cable through the conduit even if I presintall the conduit to the wall.
They have suggested instead that I allow the installer to do it with clipped cable, but then get an electrician in to run it through conduit afterwards. WTF?! I have to allow an installer to vandalise my render with cable clips, then pay for someone else to do it the way I want?!
Is there any feasible technical reason they cannot do what I'm asking? Or are they just being typical corporate robots and not able to deviate from their pre-defined script?
If you were an installer... would someone asking for a bit of conduit really be too far out of your comfort zone? I'm pretty sure if you used conduit you could do the whole job with T&E instead of SWA anyway and make your life easier.
Sigh.
Sigh.
