I have wondered about that... The kids climb them quite easily!Climbing up the inside of the trees and working your way along with a pruning chainsaw or cordless hedge cutter is probably as safe as the alternatives.
Blup
You're braver than me!30 years ago I decided a massive willow we had in the garden, one of two - had to go. So I set about it with a friend who had a chainsaw, initially cutting limbs off until just the main trunk was left. It can be quite scary when you are up a tree, cutting limbs off and the tree suddenly springs up as the weight of a limb comes off.
Just realised that on the Henchman website they seem to show photos of each size ladder not just generic ones, which is quite helpful.
This is essentially the sort of thing I want to do
I've seen people on them albeit smaller ones, on ground much steeper than that and it was rock steady. Tripods are inherently stable.With a bit of sloping ground just to add to the excitement! There is no way that I would get on that thing. You are much braver than me.
Expensive and access issues. And I'm not sure if people locally will hire to Joe Public without an operator. It'd probably cost less to get an arborist in.What about hiring a cherry picker?
Interesting - I'd feel far more nervous going up the big 3-section house ladder than one of these.
I hadn't really pictured it but yeah they are pretty wide I suppose they have to be for stability.I've got 2.4m and 3.6m tripod ladders (not henchman but similar), the 3.6m is quite a size to handle (width).
Looking at the specs, a 4.8m tripod takes up a footprint of 2.7mx1.8m and that is with the legs retracted!
Could you clarify what the problem is please?You're not going to be able to properly cut your hedge with it as you won't be able to do the top.
