This "smart" gas valve was dumped on the boiler manufacturers several years ago...and they fell for it. The concept was an auto adjusting boiler similar to lambda sensing in vehicles.
https://www.bertelli-partners.it/en/sgv/24
It turned out to be an absolute turkey with numerous recalls for replacement gas valves and firmware updates. The calibration routine is so long winded it rarely gets
done properly (you simply can't dump sufficient heat for long enough in a customers house) and boilers are often ripped out for something more reliable. Very few manufacturers now use it.
There is nothing smart about it, it's the most simple dumbass gas valve out there...the overarching design concept was that it must be as cheap as possible to manufacture and it's shocking how bad the quality is.
What's even more remarkable is that the German DVGW standards group was actually prepared to approve it, and that boiler manufacturers own design teams could not see the likely issues.
If anyone's familiar with controlling solenoid valves they will be be aware of how difficult it is to get any degree of repeatability due to stiction and mixing gas and air to an accurate combustable mix requires very precise control.
The firmware must apply multiple layers of dither to the PWM drive signals to overcome the hopeless design, as a consequence the microcontroller probably spends most of it's time applying these algorithms.
For the additional cost of pennies even a most basic valve suspension would eliminate much of the problems as other gas valve manufacturers have found.
