If you can get to the consumer unit safely then using the MCB is an option but MCB do not isolate the Neutral. If the oven has a fault that create an Earth leakage fault then a the RCD will still trip even if the MCB is OFF.
A double pole switch that fully isolates the oven would enable the RCD to be reset without having to get the tools and disconnect the oven.
