- Joined
- 8 May 2017
- Messages
- 10,631
- Reaction score
- 2,865
- Country
Can't you put the rad on the wall, right side of the doorway ,or would that encroach on the other door / access ?
A vertical rad ?
A vertical rad ?
Because air is less dense than water, air collects at the top of a radiator which is provided with a bleed valve to release it. Any pipe which rises up, then back down, will likewise collect the air, but there is no provision to bleed it out. That radiator it feeds will be a constant source of problems of no flow, needing frequent attempts to clear the airlocks.
I have seen automatic bleed valves used in such circumstances where it cannot be avoided, but both airlocks and the valves are troublesome.
I love reading your logic, it always gives me a smile. So once the air is out (increase the water pressure past 2 bar) how will it get back in? Or are you going to talk about molecular physics again LOL
Just to remind you, you were proven wrong last time.
How do you ensure all of the air is out? That is next to impossible, besides - gas is produced by the rusting of the internal surface of radiators. It will all congregate at a high point and high point where it is difficult to do anything about is the top of that pipe.
Increasing the pressure will not help much with dispelling the airlock, turning all the other radiators will, so the entire flow of the pump passes through those two pipes.
And once again, the basic laws of physics are not applicable in plumbing. Increase water pressure, increase temperature and you dissolve air into the water. It is a principle
of Henry's law of solubility.
A couple of things on this, how would going through the ceiling and then dropping down again be any different from what I have already done in terms of airlocks?
If it's just a no no in general, then in terms of chasing out floor, how would you run the pipework from it's current location?
The only long term satisfactory fix, is to have a reasonably constant rise up to a point where air can be bled - in this case the radiator. Your options really are limited to bleed valves at the top of the loop, or chasing the floor, or moving the radiator to a more suitable location.
When you do this is there anything easier than using an sds,
Angle grinder, with a concrete cutting disk, to make two tramlines, then SDS to chop out between the tramlines.
Yeah made the run now, didnt have an angle grinder so used a cordless tool with a smaller diamond disc that done the same sort of thing, used an SDS but found my 15kg breaker was handy! I have conduit to run the copper pipe in so no worries with corrosion, with copper joints that are soldered can be buried right?
Do they have to be insulated? it's only about 1.5 metres.Yes with insulation
