Worth Putting Underfloor heating in the kitchen?
9 Jun 2010
London
I've just replaced the joists in the kitchen (uneven floor due to now repaired structural issue).
The kitchen was gutted and I have a new one to go in. The Area is 4.4m x 5.6m but a U shape as it has a structural wall down the middle.
We're going to have either tiles or possible laminate down. Because of where the units will run, and that we have 2 very large windows looking out on the garden, there are not many places radiators can be placed (there were 2 long short ones under the windows I have removed - they can be put back)
I'm thinking underfloor heating may be worth putting in at this point, and wondered what other people's opinion was, and any recommendations, or if it wasnt a good idea. The floor area to heat would be 6m2 through the kitchen area, and 8-10m2 on the other side of the structural wall (the other side of the U)
Only consider it if you have an insulated floor to current building regs.
Otherwise you will struggle to get enough heat and if electric running costs will be too much.
if a wet system, you can’t really just use the old rad tails…..
Because of the unusual layout of the bungalow which is on a slope, you walk down stairs to the garden and a few rooms at the back, the ceiling of one room including the boiler room came down to replace the joists so insulating isn't an issue / massive difficulty.
I've see the wet floor heating and the one between joists looks feesable. The boiler room (unvented cylinder system if that's right was installed last year) is under the kitchen area too.
if its worth doing, can I run pipes / a system ready for a plumber to hook up?
