I renovated my flat earlier this year and installed a new CH system as below:
* Vaillant ECO Tec Pro 24 combi boiler
* Nest Thermostat
* Water UFH for living room
* Radiators for bedrooms
Everything above is new, including the pipes.
Yesterday the boiler stopped working, showing F22 error code and 0.5 bar pressure. I turned heating to OFF via Nest thermostat, waited for 10 min, and turned heating on again. The boiler then worked again, water pressure increased to 1.5 bar, and I had both CH and hot water.
Today the same thing happened again, and I had to turn heating OFF then ON to get the it work. The Nest thermostat never reports any error (despite room temp never goes up). I had to look at the boiler display screen to get the error message.
Do you think there is a leak in my central heating system..? Or there can be other causes? Thank you so much!
thanks
Patrick
* Nest Thermostat
thanks
Patrick
