Hi All
Getting a 40mm Oak worktop delivered on Saturday and i will need to cut this down and install an opening for a 800mm butler sink.
I am going to get hold of a butler sink template but not too sure which bits to purchase for the router.
According to the spec, for the recess (which i am assuming is the butler sink opening) is a 12.7mm at least 50.8mm in length with a 30mm guide bush.
I am not too sure if i need a plunge cut one or a straight cut one.
As the worktop will be 40mm thick i dont know if i need to cut this in one go or do different depths, i am going to be using 1/2 inch bits but i guess i will need a few different depth bits?
My router has a guide bush of 30mm but i am not too sure if these just get put on the bits or whether the bits need to have these already? I have seen some with and some without.
The same thing will apply to the drip channel on the inside.
Another question though, the worktop needs to be trimmed to the right length. I am planning on using a jigsaw to get it in the ballpark and then cut with the router, would this be using the same bits?
