Fitted wardrobes doors not lining up
26 Apr 2020
Hello peeps
Hope you are all well
Need some advice moved in to a new property in one of the bedrooms lovely fitted wardrobes. Only issue is the doors don't line up some are higher then others . I have looked at the hinges and on some of the doors the screws is right up against the bracket so no move to move door down
Any advice how I can align the doors
I have attached a image one of the order is higher then the other. But the hinges doesn't give me way to move the door up .
I am confused. In those images the hinge is at its lowest position, not the highest.
Some of that may be horizontal alignment issues, not requiring the hinge plate to be moved.
The images are of the left door which is already at its high point, what are the hinges like on the right door?
Blup
The images of the hinges are of the left door
The right door lines up with all the other doors to the right. I have attached images of hinges of right door
How do I go about aligning them ? Just put in the centre Hinge first ?
