Containers for screws and bolts
^woody^ said:
I've had 50 jam jars in the Transit for a few years now.
Speed bumps can be problematic and I'm still trying to lose the 3 stone I put on emptying the jars, but otherwise not a bad idea
The classic 'old boy' storage system
Yes. The only thing missing is the rust!
Put just a few in the sections and rest kept in their boxes. Seems a bit empty. Gonna add some self tappers and thunderbolts
What thickness are they going through? (i.e shelf bracket, batten or pattress, etc) What is the wall made of?
Into Brick, behind plaster or if something light just into plaster or plasterboard. Yep through brackets or just straight into a wall I usually use Fischer Duo plugs. 6mm.
Either. I'd go for 4.5mm screws over 4.0mm, but I tend to be a bit belt and braces. I like to get 40 to 50mm of screw into the masonry or timber if I can, but again personal preference
Make sure that your shelf us close fitting and has a lip around the edges (it only needs to be 5 to 10mm high). Screw a chain plate staple at either side of the shelf:
and use one (or more) of these :
to keep the boxes in place as you go hare-arsing round country lanes
The sizes of screws you get depends on the jobs you are doing. At one time I bought a big Spax selection which was about £50 at the time and just added to it over time (mostly Spax, Reisser and ForgeFast screws). On the one hand for structural stuff you'll find sizes 5 x 50/70/100 and 6 x 70/100 very handy, whilst door ironmongery requires 3 x 12/16/20/25 and 3.5 x 12/16/20/25s in BZP finish. For kitchen work I have a selection of Hospa screws, small angle brackets, Euro screws, shelf pins, door knob screws, csbinet joiners, etc. As I said - different kits for different tasks, and everyone has different screw needs
For the smaller sized screws is the colour important? Mine are not silver maybe bzp finish, is this important?
