Strange lighting wiring colours? Replacing fluorescent fixture
7 Aug 2021
Hello all, I’ve had a look over the sticky regarding lighting wiring and I think it doesn’t answer my question.
I’m trying to replace the long fluorescent fixture in the kitchen with an ordinary light fixture (bar/spotlight). The problem is that there’s some bizarre colours (peach, orange and pink) that I’ve not encountered before and can’t seem to find anything about online. How should I proceed with this? Do I just snip the redundant cables away and just use the relevant ones? Which ones should I keep?
Here are some images of the terminal
Thanks in advance. If this question doesn’t warrant a thread then please do delete this.
They are part of the fitting you are replacing
I see. On a closer inspection it seems like the pink cable is from the house wiring, and is a live cable. Not sure why they used that colour though, I guess so it doesn’t clash with the fluorescent cabling colour scheme.
Why would you think that; it doesn't even go into the connector block?
Surely the house supply wires are the Brown and Blue and one of the Green&Yellows - which must enter the light from outside.
Surely the house supply wires are the Brown and Blue and one of the Green&Yellows.
I think the photo doesn’t represent the colours very well, the pink goes into the terminal, it’s just more of a hot pink and looks almost red on the photo. The peach cable looks pink in the photo. The blue and brown cables are part of the fixture it seems.
If you trace the red, black & g/y they will disappear into the ceiling void, the pink will stay in the fitting
Red = live/L, Black = neutral/N, yellow/green = earth/E. Those are the only ones you are interested in, the rest are a part of the fitting and not to any standard.
