And plaster should go on everything except the wall or the ceiling you are actually working onAhem. Silicone should always end up in the t’shirt armpit. Nothing worse than smudging silicone over a new suite from your trouser leg.
You’ve not come across a top plastererAnd plaster should go on everything except the wall or the ceiling you are actually working on
I find with some cheap radiator brands from screwfix and toolstation and the like , the tails need massive amounts of PTFE, the thread tappings just seem to be slightly larger, I think the liquid stuff alone would struggleWe use loctite 55 but we still do a fair bit of screwed steel work where if you use ptfe you can't back it.
Also never seen a rad tail leak using 55 can't say that about ptfe.
Plastic Tape For EverythingPTFE stands for
I worked beside a bloke who was adamant it stood for PIPE THREAD FITTING ENGAGEMENT tapePlastic Tape For Everything
Plumbers Tape For Everything is what I was told.Plastic Tape For Everything
I use to use a plasterer on my jobs who was very reluctant to use dustsheets etc. When I commented on this (ultimately, I would have been responsible for damage) he said that his plaster goes the walls, not the carpet. It made me cringe, bit i never got any blowback. I just thought it was a bit arrogant, and customers like t see their Axminster protectedAnd plaster should go on everything except the wall or the ceiling you are actually working on
hemp and boss white ?Do you ever mix tape/thread with jointing compound? Whatever they have used on the shower valves look like a mixture of thread like material and liquid/putty.
It looks very robust, I am just curious what it would be
Are they the ones that wash the buckets out in the brand new bath??
