We have a cupboard above the stairs which you can see in the attached photo. I want to install some shelving. The back wall feels very thin, it's just a simple partition and I don't think it will take a rawlplug without it coming out the other side! I may be wrong about this but I'm planning on attaching the shelves to the two sides of the cupboard instead, which are solid walls and will definitely take more weight.
Each shelve will be 90cm long and 30cm-40cm deep. I'm looking for some advice on the most efficient way to attach the shelves to the walls. I was thinking about attaching four slotted uprights (so the shelves can be adjusted if/when needed) and using brackets. Is this the best way to do it and if so, where would be the best place to get the brackets?
And for the shelves, I was thinking about getting B&Q to cut some wood for me. Would MDF do the job? It doesn't have to be too aesthetically pleasing, more functional than anything.
I'm not the most talented DIY-er but shelves should just about be in my competency zone!
Any advice would be greatly appreciated!
TIA.
TIA.
