Boiler "serviced" for 9 years by same man...all the registrations known to man and a real if its gas you must not even look at it attitude, which being a engineer myself I thought great, must know his stuff....
Boiler started to bang on lighting, then lit and went out. Boiler man called...1 Hour of diagnosing @£85 the fault was our boiler was passed its prime and need to be replaced 12 years old and its a Biasi so you got your moneys worth.....diagnosis primary heat exchanger leak. Would order a new one and install within a week.
Boiler not working so being a curious cat opened up said boiler...water in inspection glass...ooh that's odd. Why oh why was it not draining away via the condensate trap. Remove condensate trap water gushed out....oh what a surprise. Inside the trap filled to the brim with sludge, ball valve stuck to the bottom.
Second moron arrives to fix first morons work...1/2 inch driver to remove 10mm nut off stud holding the boiler faceplate on ...wow the stud sheared, one thinks that having the word engineer in their trade title a gas safe engineer would know to perhaps spray said nuts with a little penetrating fluid or even some wd40 you know as they exposed to heat and moisture in their working environment...but no what you do is apply 120 newton of force to said mild steel nut....Then clever clogs decides to remove the sparker and flame detector with a impact driver....can you guess what happened to the mild steal pz1 screw heads...ooh you can can't you.
Lucky for him I work a a place that has all manner of goodies to fix said bodge work. Induction welding a new stud to the sheared on in situ is not difficult if your are an engineer , the kit costs less that a basic boiler. Two screws drilled out and tapped, one stud weld and a rethread we are back to the start, tap and die set are what £40 quid...but no not in the armoury of said engineer.
Still engineer 2 only charged £95 quid for the two trips, and 4 hours he took to get the boiler going out of sheer embarrassment, new insulation to replace the sodden stuff left by the swimming pool in my boiler...He had three goes a hand cleaning the electrodes, fan and face plate off method before taking some gentle advice to check the resistance with a meter...ooh was all that dark grey coating not conductive after all, whats that shiny stuff under it...has the stainless from the burner plated inself to to the electrodes in the presence of acid condensate water ???? what a surprise it would do that perhaps being a gas safe engineer does not involve some basic chemistry like all other engineers.
The end to all this was a complaint about engineer 1 to his trade association...the reply says it all..We have written to the engineer and reminded him of his basic competencies......what check the drain is clear as per the service manual ??????Ie do his job he is paid to do?
Is Gas Safe just a front for the talk bloocks dodge it and leggit brigade to shelter in? In my world if we bodge it up half of southern england starts glowing in the dark and yet we have no trade association to hide behind
Rant over.
Rant over.
